x86-based systems only.
The BIOS primary drive on your system was not detected by the Configuration Assistant program during the pre-booting phase.
If you are using old drives, they may be unsupported. Check the Solaris 7 (Intel Platform Edition) Hardware Compatibility List.
Make sure the ribbon and power cables are plugged in correctly. Check the manufacturer's documentation.
If only one drive is attached to the controller, designate the drive as the master drive by setting jumpers. Some drives have different jumper settings for a single master, as opposed to a master operating with a slave. Connect the drive to the connector at the end of the cable to reduce signal ringing that occurs when an unused connector is dangling at the end of the cable.
If two drives are attached to the controller, jumper one drive as the master (or as a master operating with a slave), and jumper the second drive as a slave.
If one drive is a hard disk and the second a CD-ROM drive, designate the drive as the slave drive by setting jumpers. It doesn't matter which drive is plugged into which drive connection on the cable.
If there are persistent problems with two drives on a single controller, attach one drive at a time to verify that each works. Jumper the drive as master or single master and use the drive connector at the end of the IDE ribbon cable to attach the drive. Verify that each drive works, then jumper the drives back into a master and slave configuration.
If the drive is a disk drive, use the BIOS setup screen to ensure that the drive type (which indicates the number of cylinders, heads, and sectors) is correctly configured. Some BIOS software may have a feature that automatically detects the drive type.
If the drive is a CD-ROM drive, use the BIOS setup screen to configure the drive type as a CD-ROM drive, when the BIOS software has this capability.
If MS-DOS does not recognize the drive, there is probably a hardware or BIOS configuration problem. For many systems, IDE CD-ROM drives are only recognized by MS-DOS if a MS-DOS CD-ROM driver has been installed.
