To mount a file system manually during normal operation, run the mount command as superuser:
# mount -F nfs -o ro bee:/export/share/local /mnt |
In this case, the /export/share/local file system from the server bee is mounted on read-only /mnt on the local system. Mounting from the command line allows for temporary viewing of the file system. You can unmount the file system with umount or by rebooting the local host.
Starting with the 2.6 release, all versions of the mount command will not warn about invalid options. The command silently ignores any options that cannot be interpreted. Make sure you verify all of the options that were used, to prevent unexpected behavior.
