If the NFS server cannot be rebooted because of work in progress, it is possible to restart rpcbind without having to restart all of the services that use RPC by completing a warm start as described in this procedure.
As root on the server, get the PID for rpcbind.
Run ps to get the PID (which is the value in the second column).
# ps -ef |grep rpcbind
root 115 1 0 May 31 ? 0:14 /usr/sbin/rpcbind
root 13000 6944 0 11:11:15 pts/3 0:00 grep rpcbind
Send a SIGTERM signal to the rpcbind process.
In this example, term is the signal that is to be sent and 115 is the PID for the program (see the kill(1) man page). This causes rpcbind to create a list of the current registered services in /tmp/portmap.file and /tmp/rpcbind.file.
# kill -s term 115 |
If you do not kill the rpcbind process with the -s term option, then you cannot complete a warm start of rpcbind and must reboot the server to restore service.
Restart rpcbind.
Do a warm restart of the command so that the files created by the kill command are consulted, and the process resumes without requiring that all of the RPC services be restarted (see the rpcbind(1M) man page).
# /usr/sbin/rpcbind -w |
