Assign your domain a domain name, and make the domain name known to each computer in the domain.
See the Solaris Naming Administration Guide if you are using NIS+ as your name service.
Establish public keys and secret keys for your clients' users using the newkey or nisaddcred command, and have each user establish his or her own secure RPC password using the chkey command.
For information about these commands, see the newkey(1M), the nisaddcred(1M), and the chkey(1) man pages.
When public and secret keys have been generated, the public and encrypted secret
keys are stored in the publickey database.
Verify that the name service is responding. If you are running NIS+, type the following:
# nisping -u
Last updates for directory eng.acme.com. :
Master server is eng-master.acme.com.
Last update occurred at Mon Jun 5 11:16:10 1995
Replica server is eng1-replica-replica-58.acme.com.
Last Update seen was Mon Jun 5 11:16:10 1995
If you are running NIS, verify that the ypbind daemon is running.
To verify that the keyserv daemon (the keyserver) is running, type the following:
# ps -ef | grep keyserv root 100 1 16 Apr 11 ? 0:00 /usr/sbin/keyserv root 2215 2211 5 09:57:28 pts/0 0:00 grep keyserv |
If the daemon isn't running, start the keyservet by typing the following:
# /usr/sbin/keyserv |
Run keylogin to decrypt and store the secret key.
Usually, the login password is identical to the network password. In this case, keylogin is not required. If the passwords are different, the users have to log in, and then do a keylogin. You still need to use the keylogin -r command as root to store the decrypted secret key in /etc/.rootkey.
You only need to run keylogin -r if the root secret key changes or /etc/.rootkey is lost.
Edit the /etc/dfs/dfstab file and add the -sec=dh option to the appropriate entries (for Diffie-Hellman authentication).
share -F nfs -o sec=dh /export/home |
Edit the auto_master data to include -sec=dh as a mount option in the appropriate entries (for Diffie-Hellman authentication):
/home auto_home -nosuid,sec=dh |
With 2.5 and earlier Solaris releases, if a client does not mount as secure a file system that is shared as secure, users have access as user nobody, rather than as themselves. With Version 2 on later releases, the NFS server refuses access if the security modes do not match, unless -sec=none is included on the share command line. With version 3, the mode is inherited from the NFS server, so there is no need for the clients to specify -sec=krb4 or -sec=dh. The users have access to the files as themselves.
When you reinstall, move, or upgrade a computer, remember to save /etc/.rootkey if you do not establish new keys or change them for root. If you do delete /etc/.rootkey, you can always type:
# keylogin -r |
