NFS Administration Guide
truss
You can use this command to see if a process is hung. It must be run by root. You can use many options with this command (see the truss(1) man page). A shortened syntax of the command is:
truss [ -t syscall ] -p pid
where -t syscall selects system calls to trace, and -p pid indicates the PID of the process to be traced. The syscall may be a comma-separated list of system calls to be traced. Also, starting syscall with a ! selects to exclude the listed system calls from the trace.
This example shows that the process is waiting for another connection request from a new client.
# /usr/bin/truss -p 243
poll(0x00024D50, 2, -1)         (sleeping...)
This is a normal response. If the response does not change after a new connection request has been made, the process could be hung. Follow the instructions in "How to Restart NFS Services" to fix the hung program. Review the instructions in "NFS Troubleshooting Procedures" to fully verify that your problem is a hung program.
