This command generates information about the RPC service running on a system. You can also use it to change the RPC service. Many options are available with this command (see the rpcinfo(1M) man page). This is a shortened synopsis for some of the options that you can use with the command:
rpcinfo [ -m | -s ] [ hostname ]
rpcinfo [ -t | -u ] [ hostname ] [ progname ]
where -m displays a table of statistics of the rpcbind operations, -s displays a concise list of all registered RPC programs, -t displays the RPC programs that use TCP, -u displays the RPC programs that use UDP, hostname selects the host name of the server you need information from, and progname selects the RPC program to gather information about. If no value is given for hostname, then the local host name is used. You can substitute the RPC program number for progname, but many users will remember the name and not the number. You can use the -p option in place of the -s option on those systems that do not run the NFS version 3 software.
The data generated by this command can include:
The RPC program number
The version number for a specific program
The transport protocol that is being used
The name of the RPC service
The owner of the RPC service
This example gathers information on the RPC services running on a server. The text generated by the command is filtered by the sort command to make it more readable. Several lines listing RPC services have been deleted from the example.
% rpcinfo -s bee |sort -n
program version(s) netid(s) service owner
100000 2,3,4 udp,tcp,ticlts,ticotsord,ticots portmapper superuser
100001 4,3,2 ticlts,udp rstatd superuser
100002 3,2 ticots,ticotsord,tcp,ticlts,udp rusersd superuser
100003 3,2 tcp,udp nfs superuser
100005 3,2,1 ticots,ticotsord,tcp,ticlts,udp mountd superuser
100008 1 ticlts,udp walld superuser
100011 1 ticlts,udp rquotad superuser
100012 1 ticlts,udp sprayd superuser
100021 4,3,2,1 ticots,ticotsord,ticlts,tcp,udp nlockmgr superuser
100024 1 ticots,ticotsord,ticlts,tcp,udp status superuser
100026 1 ticots,ticotsord,ticlts,tcp,udp bootparam superuser
100029 2,1 ticots,ticotsord,ticlts keyserv superuser
100068 4,3,2 tcp,udp cmsd superuser
100078 4 ticots,ticotsord,ticlts kerbd superuser
100083 1 tcp,udp - superuser
100087 11 udp adm_agent superuser
100088 1 udp,tcp - superuser
100089 1 tcp - superuser
100099 1 ticots,ticotsord,ticlts pld superuser
100101 10 tcp,udp event superuser
100104 10 udp sync superuser
100105 10 udp diskinfo superuser
100107 10 udp hostperf superuser
100109 10 udp activity superuser
100227 3,2 tcp,udp - superuser
100301 1 ticlts niscachemgr superuser
390100 3 udp - superuser
1342177279 1,2 tcp - 14072
This example shows how to gather information about a particular RPC service using a particular transport on a server.
% rpcinfo -t bee mountd program 100005 version 1 ready and waiting program 100005 version 2 ready and waiting program 100005 version 3 ready and waiting % rpcinfo -u bee nfs program 100003 version 2 ready and waiting program 100003 version 3 ready and waiting |
The first example checks the mountd service running over TCP. The second example checks the NFS service running over UDP.
