With this command, you can make a local file system on an NFS server available for mounting. You can also use the share command to display a list of the file systems on your system that are currently shared. The NFS server must be running for the share command to work. The NFS server software is started automatically during boot if there is an entry in /etc/dfs/dfstab. The command does not report an error if the NFS server software is not running, so you must check this yourself.
The objects that can be shared include any directory tree, but each file system hierarchy is limited by the disk slice or partition that the file system is located on. For instance, sharing the root (/) file system would not also share /usr, unless they are on the same disk partition or slice. Normal installation places root on slice 0 and /usr on slice 6. Also, sharing /usr would not share any other local disk partitions that are mounted on subdirectories of /usr.
A file system cannot be shared that is part of a larger file system already being shared. For example, if /usr and /usr/local are on one disk slice, then /usr can be shared or /usr/local can be shared, but if both need to be shared with different share options, then /usr/local must to be moved to a separate disk slice.
You can gain access to a file system that is shared read-only through the file handle of a file system that is shared read-write if the two file systems are on the same disk slice. It is more secure to place those file systems that need to be read-write on a separate partition or disk slice than the file systems that you need to share read-only.
Some of the options that you can include with the -o flag are:
The pathname file system is shared read-write or read-only to all clients.
The file system is shared read-write to the listed clients only. All other requests are denied. Starting with the Solaris 2.6 release, the list of clients defined in accesslist has been expanded. See "Setting Access Lists With the share Command" for more information. You can use this option to override an -ro option.
The options that you can use with NFS file systems only include:
This option enables an NFS server supporting the NFS version 2 protocol to be configured to do access control for NFS version 2 clients. Without this option all clients are given minimal access. With this option the clients have maximal access. For instance, on file systems shared with the -aclok option, if anyone has read permissions, then everyone does. However, without this option, it is possible to deny access to a client who should have access permissions. Whether it is preferred to permit too much access or to permit too little, depends on the security systems already in place. See "Securing Files (Tasks)" in System Administration Guide, Volume II for more information about access control lists (ACLs).
To take advantage of ACLs, it is best to have clients and servers run software that supports the NFS version 3 and NFS_ACL protocols. If the software only supports the NFS version 3 protocol, then clients get correct access, but cannot manipulate the ACLs. If the software supports the NFS_ACL protocol, then the clients get correct access and can manipulate the ACLs. Starting with release 2.5, the Solaris system supports both protocols.
You use uid to select the user ID of unauthenticated users. If you set uid to -1, the server denies access to unauthenticated users. You can grant root access by setting anon=0, but this will allow unauthenticated users to have root access, so use the root option instead.
You can use the -index=filename option to force the loading of a HyperText Markup Language (HTML) file instead of displaying a listing of the directory when a user accesses an NFS URL. This option mimics the action of current browsers if an index.html file is found in the directory that the HTTP URL is accessing. This is the equivalent of setting the DirectoryIndex option for httpd. For instance, if the dfstab file entry looks like:
share -F nfs -o ro,public,index=index.html /export/web |
these URLs will display the same information:
nfs://<server>/<dir> nfs://<server>/<dir>/index.html nfs://<server>//export/web/<dir> nfs://<server>//export/web/<dir>/index.html http://<server>/<dir> http://<server>/<dir>/index.html |
This option signals that all attempts to enable the setuid or setgid mode should be ignored. NFS clients cannot be able to create files with the setuid or setgid bits on.
The -public option has been added to the share command to enable WebNFS browsing. Only one file system on a server can be shared with this option.
The server gives root access to the hosts in the list. By default, the server does not give root access to any remote hosts. If the selected security mode is anything other than -sec=sys, then you can only include client host names in the accesslist. Starting with the Solaris 2.6 release, the list of clients defined in accesslist is expanded. See "Setting Access Lists With the share Command" for more information.
Granting root access to other hosts has far-reaching security implications; use the -root= option with extreme caution.
mode selects the security modes that are needed to get access to the file system. By default, the security mode is UNIX authentication. You can specify multiple modes, but use each security mode only once per command line. Each -mode option applies to any subsequent -rw, -ro, -rw=, -ro=, -root=, and -window= options, until another -mode is encountered. Using -sec=none maps all users to user nobody.
value selects the maximum life time in seconds of a credential on the NFS server. The default value is 30000 seconds or 8.3 hours.
In Solaris releases prior to 2.6, the accesslist included with either the -ro=, -rw=, or -root= option of the share command were restricted to a list of host names or netgroup names. Starting with the Solaris 2.6 release, the access list can also include a domain name, a subnet number, or an entry to deny access. These extensions should make it easier to control file access control on a single server, without having to change the name space or maintain long lists of clients.
This command provides read-only access for most systems but allows read-write access for rose and lilac:
# share -F nfs -o ro,rw=rose:lilac /usr/src |
In the next example, read-only access is assigned to any host in the eng netgroup. The client rose is specifically given read-write access.
# share -F nfs -o ro=eng,rw=rose /usr/src |
You cannot specify both rw and ro without arguments. If no read-write option is specified, the default is read-write for all clients.
To share one file system with multiple clients, you must enter all options on the same line, because multiple invocations of the share command on the same object "remember" only the last command run. This command enables read-write access to three client systems, but only rose and tulip are given access to the file system as root.
# share -F nfs -o rw=rose:lilac:tulip,root=rose:tulip /usr/src |
When sharing a file system using multiple authentication mechanisms, make sure to include the -ro, -ro=, -rw, -rw=, -root, and -window options after the correct security modes. In this example, UNIX authentication is selected for all hosts in the netgroup named eng. These hosts can only mount the file system in read-only mode. The hosts tulip and lilac will be able to mount the file system read-write if they use Diffie-Hellman authentication. With these options, tulip and lilac will be able to mount the file system read-only even if they are not using DH authentication, if the host names are listed in the eng netgroup.
# share -F nfs -o sec=dh,rw=tulip:lilac,sec=sys,ro=eng /usr/src |
Even though UNIX authentication is the default security mode, it is not included if the -sec option is used, so it is important to include a -sec=sys option if UNIX authentication is to be used with any other authentication mechanism.
You can use a DNS domain name in the access list by preceding the actual domain name with a dot. The dot indicates that the string following it is a domain name, not a fully qualified host name. The following entry allows mount access to all hosts in the eng.sun.com domain:
# share -F nfs -o ro=.:.eng.sun.com /export/share/man |
In this example, the single "." matches all hosts that are matched through the NIS or NIS+ name spaces. The results returned from these name services do not include the domain name. The ".eng.sun.com" entry matches all hosts that use DNS for name space resolution. DNS always returns a fully qualified host name, so the longer entry is required if you use a combination of DNS and the other name spaces.
You can use a subnet number in an access list by preceding the actual network number or the network name with "@". This differentiates the network name from a netgroup or a fully qualified host name. You must identify the subnet in either /etc/networks or in a NIS or NIS+ name space. The following entries have the same effect if the 129.144 subnet has been identified as the eng network:
# share -F nfs -o ro=@eng /export/share/man # share -F nfs -o ro=@129.144 /export/share/man # share -F nfs -o ro=@129.144.0.0 /export/share/man |
The last two entries show that it is not necessary to include the full network address.
If the network prefix is not byte aligned, as with Classless Inter-Domain Routing (CIDR), the mask length can be explicitly specified on the command line. The mask length is defined by following either the network name or the network number with a slash and the number of significant bits in the prefix of the address. For example:
# share -f nfs -o ro=@eng/17 /export/share/man # share -F nfs -o ro=@129.144.132/17 /export/share/man |
In these examples, the "/17" indicates that the first 17 bits in the address are to be used as the mask. For additional information on CIDR, look up RFC 1519.
You can also select negative access by placing a "-" before the entry. Notice that because the entries are read from left to right, you must place the negative access entries before the entry they apply to:
# share -F nfs -o ro=-rose:.eng.sun.com /export/share/man |
This example would allow access to any hosts in the eng.sun.com domain except the host named rose.
