NFS Administration Guide
How to Access NFS File Systems Using CacheFS
  1. Run the cfsadmin command to create a cache directory on the local disk.
    # cfsadmin -c /var/cache
  2. Add the cachefs entry to the appropriate automounter map.
    For example, adding this entry to the master map caches all home directories:
    /home auto_home -fstype=cachefs,cachedir=/var/cache,backfstype=nfs
    Adding this entry to the auto_home map only caches the home directory for the user named rich:
    rich -fstype=cachefs,cachedir=/var/cache,backfstype=nfs dragon:/export/home1/rich
    Note -
    Options that are included in maps that are searched later override options set in maps that are searched earlier. The last options found are the ones that are used. In the previous example, a specific entry added to the auto_home map only needs to include the options listed in the master maps if some of the options needed to be changed.
