/home auto_home -nosuid |
The nosuid option prevents users from creating files with the setuid or setgid bit set.
This entry overrides the entry for /home in a generic local /etc/auto_master file (see the previous example) because the +auto_master reference to the external name service map occurs before the /home entry in the file. If the entries in the auto_home map include mount options, then the nosuid option is overwritten, so either no options should be used in the auto_home map or the nosuid option must be included with each entry.
Do not mount the home directory disk partitions on or under /home on the server.
