In this example, browsability of the /net directory is disabled. The same procedure can be used for /home or any other autofs mount points.
Check the automount entry in /etc/nsswitch.conf.
For local file entries to take precedence, the entry in the name service switch file should list files before the name service. For example:
automount: files nisplus |
This is the default configuration in a standard Solaris installation.
Check the position of the +auto_master entry in /etc/auto_master.
For additions to the local files to take precedence over the entries in the name space, the +auto_master entry must be moved below /net:
# Master map for automounter # /net -hosts -nosuid /home auto_home /xfn -xfn +auto_master |
A standard configuration places the +auto_master entry at the top of the file. This prevents any local changes from being used.
Add the -nobrowse option to the /net entry in the /etc/auto_master file.
/net -hosts -nosuid,nobrowse |
On all clients: run the automount command.
The new behavior takes effect after running the automount command on the client systems or after a reboot.
# /usr/sbin/automount |
