Using the nistbladm command, add or delete the changes you want to the direct map.
See the Solaris Naming Administration Guide.
If you added or deleted a mount-point entry in step 1, run the automount command.
Notify your users of the changes.
Notification is required so that the users can also run the automount command as superuser on their own computers.
If you only modify or change the contents of an existing direct map entry, you do not need to run the automount command.
For example, suppose you modify the auto_direct map so that the /usr/src directory is now mounted from a different server. If /usr/src is not mounted at this time, the new entry takes effect immediately when you try to access /usr/src. If /usr/src is mounted now, you can wait until the auto-unmounting takes place, then access it.
Because of the additional steps, and because they do not take up as much space in the mount table as direct maps, use indirect maps whenever possible. They are easier to construct, and less demanding on the computers' file systems.
