NFS Administration Guide
Hierarchical Mounting
When multiple layers are defined in the automounter files, the mount process becomes more complex. If the /etc/auto_shared file from the previous example is expanded to contain:
# share directory map for automounter
ws       /       gumbo:/export/share/ws
         /usr    gumbo:/export/share/ws/usr
The mount process is basically the same as the previous example when the /share/ws mount point is accessed. In addition, a trigger node to the next level (/usr) is created in the /share/ws file system so that the next level can be mounted if it is accessed. In this example, /export/share/ws/usr must exist on the NFS server for the trigger node to be created.
Caution - Caution -
Do not use the -soft option when specifying hierarchical layers. Refer to "Autofs Unmounting" for an explanation of this limitation.
