NFS Administration Guide
Executable Autofs Maps
You can create an autofs map that will execute some commands to generate the autofs mount points. You could benefit from using an executable autofs map if you need to be able to create the autofs structure from a database or a flat file. The disadvantage to using an executable map is that the map will need to be installed on each host. An executable map cannot be included in either the NIS or the NIS+ name service.
The executable map must have an entry in the auto_master file.
/execute    auto_execute
Here is an example of an executable map:
#!/bin/ksh
# executable map for autofs
case $1 in
	         src)  echo '-nosuid,hard bee:/export1' ;;
esac
For this example to work, the file must be installed as /etc/auto_execute and must have the executable bit set (set permissions to 744). Under these circumstances running the following command:
% ls /execute/src
causes the /export1 file system from bee to be mounted.
