Mail Administration Guide
Uses for Aliases Files
You create mail aliases for global use in the NIS+ mail_aliases table, the NIS aliases map, or in local /etc/mail/aliases files. You can also create and administer mailing lists using the same alias files.
Depending on the configuration of your mail services, you can administer aliases by using the NIS or NIS+ name service to maintain a global aliases database or by updating all the local /etc/mail/aliases files to keep them synchronized.
Users can also create and use aliases. They can create aliases either in their local ~/.mailrc file, which only they can use, or in their local /etc/mail/aliases file, which can be used by anyone. Users cannot normally create or administer NIS or NIS+ alias files.
