Mail Administration Guide
sendmail Configuration File
A configuration file controls the way that sendmail performs its functions. The configuration file determines the choice of delivery agents, address rewriting rules, and the format of the mail header.
The sendmail program uses the information from the /etc/mail/sendmail.cf file to perform its functions. Each system has a default sendmail.cf file installed in the /etc/mail directory. You do not need to edit or change the default configuration file for mail servers or mail clients. The only systems that require a customized configuration file are mail hosts and mail gateways.
The Solaris operating environment provides two default configuration files in the /etc/mail directory:
  1. A configuration file named main.cf for the system (or systems) you designate as the mail host or a mail gateway
  2. A configuration file named subsidiary.cf (a duplicate copy of the default sendmail.cf file)
The configuration file you use on a system depends on the role the system plays in your mail service.
The following list describes some configuration parameters you might want to change, depending on the requirements of your site:
