Mail Administration Guide
To List the Entire Contents of the NIS+ mail_aliases Table
    Type aliasadm -l and press Return.
This lists the contents of the aliases table in alphabetical order by alias.
Note -
If you have a large aliases table, listing the entire contents can take some time. If you are searching for a specific entry, pipe the output through the grep command (aliasadm -l | grep entry) so that you can use the grep search capability to find specific entries.
