A mail host resolves email addresses and reroutes mail within your domain. A good candidate for a mail host is a system that connects your systems to the outside world or to a parent domain.
Become root on the mail host system.
Verify the hostname configuration.
Run the check-hostname script to verify if sendmail will be able to identify the fully qualified hostname for this server:
% /usr/lib/mail/sh/check-hostname hostname phoenix OK: fully qualified as phoenix.eng.acme.com |
If this script is not successful in identifying the fully qualified hostname, you need to add the fully qualified hostname as the first alias for the host in /etc/hosts.
Use the Administration Tool to edit the /etc/hosts file.
Add the word mailhost and mailhost.domainname after the IP address and system name of the mail host system. The system is designated as a mail host. The domainname should be identical to the string given as the subdomainname in the output of this command: /usr/lib/sendmail -bt -d0 </dev/null.
% /usr/lib/sendmail -bt -d0 </dev/null
Version 8.9.0+Sun
Compiled with: MAP_REGEX LOG MATCHGECOS MIME7TO8 MIME8TO7 NAMED_BIND
NDBM NETINET NETUNIX NEWDB NIS NISPLUS QUEUE SCANF SMTP
USERDB XDEBUG
============ SYSTEM IDENTITY (after readcf) ============
(short domain name) $w = phoenix
(canonical domain name) $j = phoenix.eng.acme.com
(subdomain name) $m = eng.acme.com
(node name) $k = phoenix
Create an entry for the new mail host in one of the hosts files.
If you are using NIS or NIS+, add an entry including a host alias called mailhost and mailhost.domainname to the host entry for the new mail host.
If you are not using NIS or NIS+, you must create an entry in /etc/hosts for each system on the network. The entry should use this format: IP_address mailhost_name mailhost mailhost.domainname
Type cp /etc/mail/main.cf /etc/mail/sendmail.cf and press Return.
This copies and renames the /etc/mail/main.cf file.
Restart sendmail and test your mail configuration.
See "How to Test the Mail Configuration" for information.
