Solaris 7 (SPARC Platform Edition) Installation Library
Error Messages
le0: No carrier - transceiver cable problem
Problem
How to Fix the Problem
The system is not connected to the network.
If this is a non-networked system, ignore this message. If this is a networked system, make sure the Ethernet cabling is attached securely.
The file just loaded does not appear to be executable
Problem
The system cannot find the proper media for booting.
Verify that the system has been set up properly to install over the network from an install server. For example, make sure you specified the right platform group for the system when you set it up. Also, if you did not copy the Solaris CD, make sure the Solaris CD on the install server is mounted and accessible.
boot: cannot open /kernel/unix
Problem
SPARC-based systems only.
This error occurs when you override the boot file location by explicitly setting it to /kernel/unix. In the Solaris 2.6 release, the kernel no longer resides in /kernel/unix, but in /platform/<arch>/kernel/unix.
Reset the boot file in the PROM to " " (blank).
Can't boot from file/device
Problem
The installation program can't find the Solaris CD in the system's CD-ROM drive.
Make sure:
  • The CD-ROM drive is installed properly or is turned on
  • The Solaris CD is inserted into the CD-ROM drive
WARNING: clock gained xxx days -- CHECK AND RESET DATE!
Problem
This is an informational message.
Ignore the message and continue with the installation.
