Before you start the installation process, verify that the systems on which you plan to install AnswerBook2 server software meet the hardware and software requirements listed in Table 9-2 and Table 9-3.
Table 9-2 Hardware and Software Requirements|
Component |
Requirement |
Documentation server system hardware |
SPARCstationTM 2 computer or higher (SPARCstation 5 computer recommended) Intel-based personal computer |
Operating environment |
Solaris 7 (for SPARC or x86, as appropriate) |
Admin GUI and AnswerBook2 client viewer |
Any HTML 3.2-compliant browser, such as Netscape Navigator, HotJava, or Lynx |
Table 9-3 Disk Space Requirements Table
Directory Path |
Description |
Space |
/usr/lib/ab2/ |
Contains executable files, server processing files, library files, and graphics and document source files for the product interface. |
26.0 Megabytes |
/var/log/ab2/ |
Contains catalog files and log files, if logging functions are enabled. |
5.0 Megabytes (recommended - grows as server is used) |
/etc/init.d/ab2mgr |
Server start-up file |
0.01 Megabytes |
In addition, you need to set aside some amount of disk space (600 Megabytes recommended) for the actual book files. The exact amount of space depends on the specific collections. For a list of collections available on the Solaris 7 Documentation CD, see the README file located on that CD.
