Solaris 7 (Intel Platform Edition) Installation Library
Launching the AnswerBook2 Viewer
The system launches a web browser with the URL for the document server if you are running the Solaris 2.6 (or later version) operating environment and you either:
The system determines the web browser to launch by searching your path and launching Netscape NavigatorTM or the first web browser it finds. For information on how the system determines the URL for the documentation server, see "Finding a Documentation Server".
You can also access the AnswerBook2 product from any HTML 3.2-compliant web browser. Start your web browser and enter the appropriate documentation server URL. For example, if your system administrator installed an AnswerBook2 documentation server on the system imaserver using the default port number, you would type the URL: http://imaserver:8888/
