The WebNFS Software Development KIT (SDK) provides remote file access for Java applications using WebNFS. Since it implements the NFS protocol directly, it requires no NFS support on the host system. It provides access to WebNFS or conventional NFS servers by way of URL file naming. The file access API is modeled after the classes in the java.io.* package and provides seamless access to both local and remote files. For updates to this SDK, go to the web site: http://www.sun.com/webnfs.
