You can install software on your local system or on a remote system with Admintool (started with the admintool command). The default location for the installation is the local system.
Use Admintool to:
Look at the software installed on the local system
Install or remove software on a local system
If you want to install or remove the software, you must run Admintool as superuser or as a user in the sysadmin group (group 14). You do not need to be superuser to look at the software packages that are already installed on a system.
