Solaris Transition Guide
Examples
Below are sample table entries followed by an interpretation of the entry..
SunOS release 4.x Command
SunOS release 5.7 Status
Alternative Available and Notes
ABI
SVID
SVR4
BSD
clntraw_create()(3N)
S
This routine is still available, but is superseded by clnt_raw_create()(3N) in the SunOS release 5.7 and SVR4 versions.
A
A
S
N
The clntraw_create()() routine exists in this release, but it also has a replacement routine: clnt_raw_create()(). Applications that use clntraw_create()() will continue to work in this release and on other SVR4-compliant systems, but these applications should be updated to use clnt_raw_create()(). clntraw_create()() is considered obsolete, and may not be available in future releases. If you want your application to be ABI-- or SVID-- compliant, use clnt_raw_create()().
ABI
SVID
SVR4
BSD
putpwent()(3)
S
S
S
S
N
The SunOS release 4.x putpwent()() routine and the SunOS release 5.7 routine are the same. Applications that use this routine will behave as they did in the SunOS release 4.x software.
