In the OpenWindows environment, application-wide settings are set via the Properties dialog box, accessed from the Edit menu. In CDE, application-wide settings are set via the Options areas. Options choices are generally located under the application's File menu or the separate menu item, Options.
In CDE, Properties (if they exist in an application) are found under the application's Edit menu and are used to set characteristics of an object, such as its date or name, or display identifying characteristics of an object, such as typefaces. In CDE, format settings are usually found under the Format menu and enable margin and paragraph alignment to be set for a single paragraph, file, or message.
CDE Global options are like the properties you set from the Workspace menu in the OpenWindows environment. You now set these properties from the CDE Style Manager application. See Chapter 7, "Customizing the Desktop Environment," in Solaris Common Desktop Environment: User's Guide.
