The SunOS release 4.x dkinfo command is no longer available. To print device information, use prtvtoc(1M) instead of dkinfo.
The prtvtoc command reports the important information stored on a disk's label, including information on the disk's partitions. For more information about prtvtoc, see System Administration Guide, Volume I.
The following screen shows sample output for the SunOS release 5.7 prtvtoc command.
# prtvtoc /dev/rdsk/c0t2d0s2
* /dev/rdsk/c0t2d0s2 partition map
* Dimensions:
* 512 bytes/sector
* 36 sectors/track
* 9 tracks/cylinder
* 324 sectors/cylinder
* 1272 cylinders
* 1254 accessible cylinders
* Flags:
* 1: unmountable
* 10: read-only
* First Sector Last
* Partition Tag Flags Sector Count Sector Mount
Directory
0 0 00 0 32724 32723 /
1 0 00 32724 65448 98171
2 0 00 0 406296 406295
6 0 00 98172 308124 406295 /usr
