truss is a new utility, provided to trace system calls performed, signals received, and machine faults incurred. It also has an option that enables entry and exit tracing of user-level function calls executed by the traced process. truss offers several significant improvements over the SunOS release 4.x trace(1) command, including the ability to follow forked processes and to deal with multithreaded processes.
Also, the truss utility traces the system calls, signals, and machine faults of a process. It has been enhanced with a new option to enable entry and exit tracing of user-level function calls executed by the traced process.
The following example shows a summary of traced calls for the date command. With the -c option, truss does not display the trace line by line. Instead, it counts the system calls, signals, and faults, and displays a summary.
example% truss -c date
Fri Sep 18 14:31:30 PDT 1992
syscall seconds calls errors
_exit .00 1
read .00 7
write .00 1
open .03 12
close .00 12
time .00 1
brk .01 4
lseek .00 1
fstat .00 4
ioctl .00 1
execve .00 1
mmap .01 17
munmap .00 8
sys totals: .05 70 0
usr time: .03
elapsed: .28
See the truss(1) man page for complete details on all truss options. There are a number of other Solaris 7 debugging tools based on proc(4) such as pmap(1).
