The /etc directory contains system configuration information. Several files and subdirectories have been added, removed, or changed.
File system commands, such as mount*, have been moved to subdirectories of the /usr/lib/fs directory.
The SunOS release 4.x /etc/fstab file has been replaced by /etc/vfstab.
Initialization scripts, such as rc, rc.boot, rc.local, and rc.single, are not available in the SunOS release 5.7 software. They are replaced by the scripts shown in Table 9-7, which are run by their corresponding run control files. Table 9-8 describes the subdirectories that have been added to the SunOS release 5.7 /etc directory.
Scripts |
Run Control Files |
/sbin/rc0 |
/etc/rc1.d |
/sbin/rc1 |
/etc/rc2.d |
/sbin/rc2 |
/etc/rc3.d |
/sbin/rc3 |
/etc/rc4.d |
/sbin/rc4 |
/etc/rc5.d |
/sbin/rc5 |
/etc/rc6.d |
/sbin/rc6 |
/sbin/rcS |
Table 9-8 Additions to the /etc Directory
Subdirectory |
Description |
Defines default system configuration |
Defines Internet services configuration |
Defines LP system configuration |
Defines installed optional software |
Defines run-state transition operations |
Defines Service Access Facility (SAF) configuration |
In the SunOS release 5.7 software, the virtual file system file /etc/vfstab replaces the /etc/fstab file. In the virtual file system architecture, the /etc/vfstab file provides default file system parameters used by the generic commands for file system management. For information about these commands, see "Generic File System Commands".
In addition to the name change, the /etc/vfstab file is different from the /etc/fstab file in the following ways:
A device to fsck field has been added to specify the names of raw devices to be checked by fsck.
An automount field has been added to control the routine mounting of file systems by mountall (the automount daemon does not use this field).
The freq field, which specified the number of days between dumps, has been eliminated.
The file system table has seven fields, each separated by a tab. Table 9-9 explains the field entries.
You must have an entry in each field in the /etc/vfstab file. If there is no value for a field, be sure to type a dash (-).
Field Name |
Content |
device to mount |
The entry in this field may be any of the following: The block special device for local UFS file systems (for example, /dev/dsk/c0t0d0s0) The resource name for remote file systems (for example, myserver:/export/home for an NFS system) The name of the slice on which to swap (for example, /dev/dsk/c0t3d0s1) The /proc directory and proc file system type CD-ROM as hsfs file system type /dev/diskette as pcfs or ufs file system type This field is also used to specify swap file systems. For more information on remote file systems, see NFS Administration Guide . |
device to fsck |
The raw (character) special device that corresponds to the file system identified by the device to mount field (for example, /dev/rdsk/c0t0d0s0). This field determines the raw interface that is used by fsck. Use a dash (-) when there is no applicable device, such as for a read-only file system or a network-based file system. |
mount point |
The default mount-point directory (for example, /usr for /dev/dsk/c0t0d0s6). |
FS type |
The type of file system identified by the device to mount field. |
fsck pass |
The pass number used by fsck to determine whether to check a file system. When the field contains a dash (-), the file system is not checked. When the field contains a value of 1 or more, the file system is checked; non-UFS file systems with a 0 fsck pass are checked. For UFS file systems only, when the field contains a 0, the file system is not checked. When fsck is run on multiple UFS file systems that have fsck pass values greater than 1 and the preen option (-o p) is used, fsck automatically checks the file systems on different disks in parallel to maximize efficiency. When the field contains a value of 1, the file system is checked sequentially. Otherwise, the value of the pass number does not have any effect. In SunOS 5.6 system software, the fsck pass field does not explicitly specify the order in which file systems are checked. |
automount? |
yes or no for whether the file system should be automatically mounted by mountall when the system is booted. An auto in the fourth column of your SunOS release 4.x /etc/fstab would translate to a "yes" in this column; a noauto, a "no." Note that this field has nothing to do with the automount program. |
mount options |
A list of comma-separated options (with no spaces) that are used in mounting the file system. Use a dash (-) to show no options. See the mount(1M) man page for a list of the available options. |
For detailed information about the /etc/vfstab file, see System Administration Guide, Volume I.
The SunOS release 5.7 software contains an /etc/shadow file, which includes entries that force password aging for individual user login accounts. The /etc/shadow file also contains encrypted passwords. The /etc/shadow file does not have general read permissions. This prevents general access to the encrypted passwords that formerly appeared in the /etc/passwd file.
