Table 9-14 shows the file and directory monitoring commands and changes, where they apply.
Table 9-14 File and Directory Monitoring Commands|
Command |
Information Provided |
Change (if applicable) |
Size, age, permissions, owner of files |
None |
Total size of directories and their contents |
None |
Disk space occupied by file systems, directories, or mounted resources; used and available disk space |
The SunOS release 4.x version of this command provides a different output format containing somewhat different output than the SunOS release 5.7 df command. The SunOS release 5.7 -k option provides output formats similar to those in the SunOS release 4.x command. The SunOS release 4.x df -t filesystem type reports on files of the specified type, whereas the SunOS release 5.7 df-t command prints full listings with totals. |
Number of blocks owned by users |
None |
Names of files meeting search criteria |
The -n cpio-device SunOS release 4.x option is not available in the SunOS release 5.7 command. Write the current file on device in cpio -c format. |
