You define, specify, and create a new file system using either the newfs(1M) or the mkfs(1M) command. The following sections highlight changes in the newfs and mkfs commands.
The SunOS release 5.7 newfs command is a convenient front end to the mkfs command. The newfs command does not support the virtual file-system architecture; it is intended for creating UFS-type file systems only. When you use newfs, it calls and passes arguments to mkfs, which does the real work when creating a ufs file system.
The newfs command accepts only names that conform to the SunOS release 5.7 device naming conventions (see "Device Naming Conventions").
The SunOS release 5.7 mkfs command differs significantly from the SunOS release 4.x version of the command. The SunOS release 5.7 version provides for different file system types, and its command syntax is entirely different (see "Generic File System Commands"). Like newfs, mkfs accepts only names conforming to the SunOS release 5.7 device naming conventions.
Although mkfs now supports different types of file systems, in practice it is almost always used to create ufs file systems. However, mkfs isn't usually run directly; it is usually called by the newfs command.
See mkfs(1) man pages for additional details.
