The ufsrestore command in the SunOS release 5.7 software is similar to the restore command in the SunOS release 4.x software. You will be able to restore backups made with the SunOS release 4.x dump command with one exception: you cannot restore multivolume backups from diskette. If you have backup scripts that invoke restore, change them to invoke ufsrestore instead.
