Run the install4x program on a server with the Solaris 7 operating environment using one of the three procedures listed in the following section.
If the system has a local CD-ROM drive, see "Using a Local CD-ROM Drive"
If the system will use a remote CD-ROM drive on a system running the Solaris 7 operating environment, see "Using a Remote CD-ROM Drive (Solaris 7 Software)"
If the system will use a remote CD-ROM drive on a system running the SunOS release 4.x software, see "Using a Remote CD-ROM Drive (SunOS Release 4.x Software)"
Insert the SunOS release 4.x CD into the CD-ROM drive before you proceed.
If you are running install4x on a system with a local CD-ROM drive, after you install the CD into the drive, Volume Management automatically mounts the CD directory on /cdrom/volume1/s0.
If install4x is to use a CD-ROM drive on a remote system running the Solaris 7 operating environment, after you install the CD into the drive, Volume Management automatically mounts the CD directory on /cdrom/volume1/s0. Then type the following command.
# share -F nfs -o ro /cdrom/volume1/s0 |
If you are not sharing other NFS systems at boot time, you need to invoke the mountd(1M) and nfsd(1M) daemons.
Type the following commands on the local system.
# mkdir /cdrom
# mount -F nfs -o ro cd-host:/cdrom/volume1/s0 /cdrom |
If install4x is to use a CD-ROM drive on a remote system that is running the SunOS release 4.x software, type the following as superuser on the remote system.
# mkdir /cdrom
# mount -t hsfs -r /dev/sr0 /cdrom |
Once you have typed the previous commands, edit the /etc/exports and insert the following line.
/cdrom -ro |
Then type the following command on the remote system.
# exportfs /cdrom |
# mkdir /cdrom
# mount -F nfs -o ro cd-host:/cdrom /cdrom |
