System configuration information is now set in the /etc/system file. This file also modifies the kernel's treatment of loadable modules. The file contains commands of the form:
set parameter=value
For example, in the SunOS release 4.x software, MAXUSERS was set using config(8). In the Solaris 7 operating environment, it is set in the /etc/system file with the following line:
set maxusers = number |
Commands that affect loadable modules are of the form:
set module:variable=value
Changes made to the /etc/system file only take effect when you reboot your system (see the system(4) man pages).
