Solaris Transition Guide
User and Group Administration Choices
You can add, modify, and remove users and groups through the command-line interface using useradd, userdel, and usermod. Although these commands are not as robust as Admintool, they do enable you to do most of the tasks supported by Admintool from the command line without running the OpenWindows or CDE software.
The useradd, userdel, and usermod commands are similar to editing the /etc files in that they also affect only the local system. These commands cannot be used to change any information in the network naming service. However, you can use useradd to verify the uniqueness of the user name and user ID and the existence of group names in the network naming service.
