Click the Front Panel button for the workspace whose name you want to change.
That workspace is displayed.
Click the workspace's Front Panel button again.
The button becomes a text field.
Edit the workspace's name in the text field.
Once you've renamed the workspace, press Return.
Press Alt+Tab until the keyboard focus, as shown by the highlight, is on the Front Panel.
Press the arrow keys to move the highlight to the button for the workspace you want to rename.
Press Shift+F10 to display the workspace button's pop-up menu.
Press the Down Arrow key to select the Rename item, then press Return.
