Choose Options from the File menu.
The Calendar Options dialog box is displayed.
Choose Editor Defaults from the Category menu.
Optional. Change the default appointment duration in the Duration field.
Optional. Change the default appointment start time by choosing from the Start menu.
Select Beep, Flash, Popup, or Mail reminders.
Beep |
Causes your system to emit an electronic beep |
Flash |
Causes your calendar to flash |
Popup |
Displays a reminder dialog box |
Sends electronic mail |
Edit the default time intervals if necessary.
The time interval fields are active for each reminder you select. They specify the time before an appointment that the reminder is activated.
Choose a privacy option from the Privacy menu.
Others See Time Only |
The default - displays only the time of an appointment so others can see you're busy |
Others See Time and Text |
Displays the time and text of an appointment in your calendar |
Show Nothing |
Displays nothing about an appointment in your calendar for maximum privacy |
Click Apply to apply the new defaults to all future appointments.
Click Cancel to close the Calendar Options dialog box.
