Calendar's tool bar provides controls for quick navigation through calendars. The tool bar controls and their functions are described in Table 11-1.
Table 11-1 Calendar Tool Bar Icons
Control |
Function |
Appointment Editor icon opens the Appointment Editor so you can insert, delete, or edit Calendar appointments. |
To Do Editor icon opens the To Do Editor so you can create, modify, update, or set reminders for things you have to do. |
Previous View arrow changes the Calendar view to display the view before the current view. For example, if you are viewing August in Month view, clicking the Previous View arrow changes the Calendar display to July. |
Today changes the Calendar view to display the current day in the format you are viewing. For example, if you are viewing by month, clicking Today displays the current month. |
Next View arrow changes the Calendar view to display the view after the current view. For example, if you are viewing August in Month view, clicking the Next View arrow changes the Calendar display to September. |
Day View icon displays the calendar you are viewing with one day's appointments in the window plus a three-month mini-calendar. |
Week View icon displays the calendar you are viewing with a week's appointments in the window plus a week grid showing scheduled times. |
Month View icon displays the calendar you are viewing with a month's appointments in the window. |
Year View icon displays the calendar you are viewing with a year in the window. Appointments are not displayed. |
