Each object in File Manager has a pop-up menu. The File Manager window itself has a pop-up menu viewable when the pointer is placed in a location in the view window outside the boundaries of the individual file or folder objects.
Point to the icon whose pop-up menu you want to display and press mouse button 3.
To choose a command from the menu, drag to the command, then release. Or, click the command.
