Solaris Common Desktop Environment: User's Guide
To Configure the Headers
  1. Choose Set View Options from the View menu.
  2. Determine which headers to display:
    • Select Iconic Path to show current folder path as a string of folder icons at the top of the window.
    • Select Text Path to show the current folder's full path name in a text field above the view pane.
    • Select Message Line to show a count of the number of files in the folder. The line will appear at the bottom of the window.
  3. To implement the chosen option and close the Set View Options dialog box, click OK.
    To implement the chosen option and leave the Set View Options dialog box open, click Apply.
