Solaris Common Desktop Environment: User's Guide
Keyboard
  1. Select the icon.
  2. Choose Copy to from the Selected menu.
  3. Type a name into the Destination Folder text field.
    Note that this must be the new full path name for the file. For example, if you want to copy the file report into the folder /u/john, you would type /u/john.
  4. Click OK or press Return.
    To close the Copy File dialog box without copying a file, click Cancel or press Esc.
