Select the area of the icon you want to copy using the Selection tool.
Choose Copy from the Edit menu.
Choose Paste from the Edit menu.
Position the outline where you want to paste the copy, and then click.
You may repeat steps 3 and 4 as many times as you like to paste multiple copies of the region you copied.
