To Display the Palette Automatically
You normally display the Image Viewer Palette by choosing Palette from the Edit menu. However, you can also automatically display the palette whenever you open a document:
Choose Options from the File menu.
Select Display Palette On Opening Document.
Click OK or Apply.
