Certain types of configurations (for example, X terminals) do not provide a Command Line Login mode option.
To enter Command Line Login mode:
Choose Command Line Login from the Options menu.
The login screen disappears and is replaced by a console prompt.
Supply your login and password as prompted.
To leave Command Line Login mode:
Type exit at a command-line prompt.
