Solaris Common Desktop Environment: User's Guide
To Display Subsets of the Processes
  1. Type your filter text into the Filter field of the Process Manager window.
    You filter text should be a string of characters that is common to the process entries of the subset or group of processes you want to display. For example, in Figure 17-1 the user is displaying all processes relating to Audio Tool.
  2. Press Return.
    Process Manager updates the processes in the scrolling pane to include only those process entries that contain an exact match of the filter text.
  3. To revert to displaying all processes, clear the Filter field and press Return.
