Solaris Common Desktop Environment: User's Guide
To Delete Text
  1. Select the text.
  2. Choose Delete from the Edit menu or press the Delete key.
    Deleted text cannot be pasted, but it can be recovered with the Undo command (see "To Undo an Edit").
    If you intend to paste the text that you delete, use the Cut command (see "To Undo an Edit").
