Solaris Common Desktop Environment: User's Guide
To Set the User Function Keys
The User Function Keys option either locks or unlocks (the default) the user function keys.
  1. If the Terminal Options dialog box is not displayed, choose Terminal from the Options menu.
  2. Click the User Function Keys button in the Keyboard Control section and choose Locked or Unlocked (the default).
  3. Click OK at the bottom of the Terminal Options dialog box or press Return to save your selection and exit the window.
    To save your selection and retain the window, click Apply.
