If the Global Options dialog box is not displayed, choose Global from the Options menu.
Click the Window Background button in the Color Control section and choose the color display you want:
Normal displays the foreground and background colors normally.
Inverse switches the foreground and background colors.
Click OK at the bottom of the Global Options dialog box or press Return to save your selection and exit the window.
