You must set the DTMOUNTPOINT environment variable if both of the following conditions are true:
The automounter is used to mount file systems.
And, remote file systems are mounted at a location other than /net.
The user's desktop processes that are automatically started when the user logs in, such as the Workspace Manager (dtwm) and File Manager (dtfile)
Applications that are started by the desktop on local or remote systems
Applications that are started by the user from a shell command line
To set DTMOUNTPOINT for these processes:
Edit the file /etc/inetd.conf:
Find the dtspcd entry and add:
-mount_point mount_point
Find the rpc.ttdbserver entry and add:
-m mount_point
For example if the automounter is being used with a mount point of /nfs, the entries in /etc/inetd.conf are:
dtspc stream tcp nowait root /usr/dt/bin/dtspcd \ /usr/dt/bin/dtspcd -mount_point /nfs rpc stream tcp wait root /usr/dt/bin/rpc.ttdbserver \ 100083 1 rpc.ttdbserver -m /nfs
Perform the procedure on your system that rereads /etc/inetd.conf. For more information, see the inetd(1M) man page.
Set DTMOUNTPOINT such that its value is inherited by user logins.
This can be done by setting the variable in /etc/dt/config/Xsession.d. For more information on setting environment variables, see "To Set Environment Variables".
