Application registration provides full application integration.
Has its own application group.
Has its desktop configuration files gathered under a single location. This group of desktop configuration files is called the registration package.
May have a registered help volume.
There are two ways an application can become registered:
When you install a desktop-smart application, registration occurs automatically. See "To Add a Desktop-Smart Application to Application Manager".
An existing application can be registered by creating a registration package. See "To Register an Existing or Non-Desktop Smart Application".
The use of a registration package makes the application easier to administer on the desktop. The registration package is created somewhere in the file system other than the locations used for desktop configuration files.
