The following steps create a personal action that starts a fax application on remote system AppServerA. The command for starting the fax application is:
/usr/fax/bin/faxcompose [filename]
Create the file HomeDirectory/.dt/types/Fax.dt.
Put the following action definition into the file:
ACTION FaxComposer { TYPE COMMAND ICON fax WINDOW_TYPE NO_STDIO EXEC_STRING /usr/fax/bin/faxcompose -c %Arg_1% EXEC_HOST AppServerA DESCRIPTION Runs the fax composer
The WINDOW_TYPE and EXEC_STRING fields describe the behavior of the action.
WINDOW_TYPE--the NO_STDIO keyword specifies that the action does not have to run in a terminal emulator window.
See "Specifying the Window Support for the Action".
EXEC_STRING--the syntax %Arg_1% accepts a dropped file. If the action icon is double-clicked, the action opens an empty fax composer window.
Save the file.
Use Icon Editor to create the following icon image files in the HomeDirectory/.dt/icons directory:
fax.m.pm, size 32 by 32 pixels
fax.t.pm, size 16 by 16 pixels
Double-click Reload Actions in the Desktop_Tools application group.
Create an executable file named FaxComposer in a directory to which you have write permission (for example, your home directory).
