Configuration files containing action definitions must meet these requirements:
The files must use the naming convention name.dt
The files must be located on the database (actions and data types) search path. The default search path is:
Personal actions--HomeDirectory/.dt/types
System-wide actions--/etc/dt/appconfig/types/language
Built-in actions--/usr/dt/appconfig/types/language. You should not use this directory.
For information on modifying the actions/data types search path, see "Setting the Value of a Search Path".
